1 - 6 of 6 Posts
· Registered
First thread/post! Have a 2001 CC F350. Usually when it is cold, but I think it did it today when warm, there is a clunk that can be heard and felt shortly after I start the engine. Seems to come from passenger side engine compartment. Any help would be greatly appreciated.
Steve
· Too Busy to Post...
Steve
Sounds like your blend door for your heat/AC moving back to position. After shut down, when the vacuum bleeds off, the door will move. After vacuum is restored, it jumps back to the position set from the cab.
· GoNavy!
Yea sounds about right mine used to do that alot, then i changed my vacuum because it was worn out and it doesn't do it as much now....i'm not saying change your pump its not hurting anything.
· MAXIMUS OVERDRIVE
Could also be the EBP valve it cycles once every time the truck is started. usually about 5-10 seconds after start up.
1 - 6 of 6 Posts
