1 - 6 of 6 Posts
So i am wanting to mount clerance lights on my 03 F250. I am looking at buying a OEM set with harness. When i drop down my headliner will the plug be there to clip into or will i have to run wires.
Canadian Eh
The plug i believe is behind the passenger side kick panel, if you get a factory roof harness it will plug right in
STILL LEARNING
16 is right. You will need the Ford cab lights and the Ford harness to run to the passenger side kick panel. It would also be a good idea to get a template so you drill the holes in the right spots
Canadian Eh
I take no credit for the drawing of this diagram, I cannot rememebr who made it. I copied it off of here a while ago just in case i needed to use it
I did my clearance lights myself to that diagram above came out real good! I bought the lights and harness off eBay for 55 bucks that came off a 2010, I had just spliced it into my parking lights and ran a ground, the drilling through the roof part was scary but just measure and re-measure use a silicone to seal the holes I've never had a leak through my roof!
Sent from my Autoguide iPhone app
Good luck! I love my clearance lights!
1 - 6 of 6 Posts
