1 - 9 of 9 Posts
Busy Busy
What are some of the methods that are good for cleaning framerails and axle/suspension in these trucks?
Motor, trans, t-case, driveshafts coming out and the fuel tank is probably getting dropped. I'm basically going to have a shell with a frame under it so I wanted to clean it up a good bit before putting everything back in.
What about the wiring? How to clean that and around that without damaging anything.
Thanks in advance.
Banning Smut
Thanks in advance.
What fer? Just to clean/paint everything?
Busy Busy
Yeah pretty much. I'm tired of having a filthy undercarriage. I used to keep the truck spotless inside and out before the forged rod motor. With the HPOP lines blowing apart, turbo blown up, oil dipstick, crank pulley leaking it has made a mess. I've corrected all of those problems but residual oil is still to be found.
Was PSD0389
I just painted the frame on my truck. I used Marine clean first to degrease the undercarriage. Then used Metal read to help convert the rust into a more paintable surface. Then I painted it with POR-15 and put a coat of black spray paint and 3 coats of clear for a topcoat.
Went from this:
To this:
Busy Busy
Discussion Starter · #5 ·
Where's the weight room?
:poke:
Was PSD0389
:poke:
haha the weight room is everywhere, sometimes I just pop a wheel off the truck and start curling it. Gotta work with your surroundings
ΜΟΛΩΝ ΛΑΒ&
Depending on the shape your frame is in, you might consider getting some of those red scotch brite disc's for an air tool to knock the loose stuff off before painting.
Went from this:
To this:
I am about to do the same thing. I really like how por 15 turns out.
Busy Busy
Discussion Starter · #9 ·
The frame is actually in very good condition. It's a Texas Truck and it has missed two main saltings where a lot of salt was put down in the past 5 years. Plus it's been covered in oil LOL.
This is why I pulled the motor.
This happened exactly one year ago and after all of the cleaning and what not I've done under there... it's time the motor had to come out to actually do it right.
1 - 9 of 9 Posts
