1 - 7 of 7 Posts
Hello I am looking for some help I have an 06 f350 and recently got these codes P2287
P2289 p0335. I have since researched them and believe the p0335 is a result of the poor idle. The truck runs and drives when driving and let off the throttle it has a best explained as a choppy idle then goes down to normal idles speed. When sitting still it is best explained as a slight miss or hiccup very brief and not to drastic. I was going to replace the IPR since the ICP is new but any suggestions will help! Thanks
"resident smarty pants"
Did you install a new ICP wiring connector also?
Was the ICP sensor you installed an OEM sensor?
You definitely still have an ICP issue. Don't just throw an IPR at it.
I purchased the truck and they told me they replaced it, I pulled it and it’s not oem and was wiring looking old. Think I should start there? Thanks
yes .
1 - 7 of 7 Posts
