1 - 5 of 5 Posts
I was just wondering if a dp f5 chip that is programmed for a 02 f250 7.3l would work in my 97 f350 without getting reprogrammed. Both trucks are automatics just not sure how much the motor programming differs. Any answer would be appreciated.
I am going to say it will not work as those newer motors ran on split shot injectors where ours run on single shot injectors.
STILL LEARNING
Plain and simple NO. The only way a used chip will work, is if it is programed for the SAME ECM code as YOURS. BTW there are probably 10-15 different codes PER YEAR
Premium Member
The chip will require a reburn. We can help you out with that. The only way a chip will swap from one truck to another is if they have the same DPC code on the PCM. A 1997 and a 2002 will not have the same code.
Feel free to contact me for more info about the reburn, or check out our reburn page HERE.
1 - 5 of 5 Posts
