1 - 9 of 9 Posts
Hey guys, i just recently bought a new to me 2008 f250. Its got the 6.4 powerstroke and today i was playing around with the system check tool. It said "cleaning exhaust filter" and my check engine light came on. Does this mean my truck is in regen? or is it just coincidence that my check engine light came on? thanks for any info!
CEL has nothing to do with regens. Speaking of regens, when you get the "cleaning" message you should drive it till complete (possibly freeway).
As far as the code/s you should find out what that's about.
Hopefully its something intermittent and will come off in time.
The code that check engine light was on for was p0000.
I have no clue what that could be
Not sure about that code. Could be that it needs to regen and won't: bad DPF and/or sensors. But, those codes are in the p240s. Notice any grey or white smoke?
Discussion Starter · #5 ·
Had a little white some once about an hour before the check engine light came up
Still running without any problems? Most on here will tell you to stop/take it straight to the shop once you see white smoke. Yours went away, though, so that's what's puzzling. I had a similar problem, and mine was bad DPF, so I deleted it and have had no problems since then.
Do you have a tuner/monitor that can run diagnostics? If not, I'd take it in and have it checked. Plenty of things can cause white smoke from the regeneration process, bad DPF (rather benign), to cracked EGR, head gaskets, etc. How's your coolant level in the degas bottle?
Discussion Starter · #7 ·
All fluid levels are good I cleared the code and it's been running good. No issues at all.. It's got me puzzled as well.... Oh well, gives me a reason to tune and delete it!
Yep. Give that truck a reason to smile... Just be careful 1) where you live re: inspections, and 2) make sure you read plenty on what tuner/tunes to use. Everyone has their likes and opinions, just make sure you research them fully and have a decision point as to what you are choosing and why. You will be happier in the long run. Good luck.
Discussion Starter · #9 ·
Thanks for all the help man. Really appreciate it. And I think I'm going to go with a spartan tuner.
1 - 9 of 9 Posts
