1 - 4 of 4 Posts
Mine is leaking so I just ordered the updated hose online (I have a 2010, you would think it would already have the updated hose but doesn't...). I've not done much on the 6.4 yet. Looks like it is on with clips that will just pop out? The end by the water pump looks hard to get to - can I get it without removing anything else?
Thanks!
It's in a tight spot but if the clip holding the hose on is facing the right direction then you don't need to remove anything else.
Clean and check the spout for scratches/pitting before sliding the new hose on.
yes it can be done my clip didnt come all the way off but if came far enough off that i could break it free as impossible as it seems just get in their and it will come out with a little persuassion
Took the clamp and moved the cac boot out of the way when I did it went pretty easy tho then for put it back I just put the hose clamp on slid over so when I put the hose on just twisted the clamp into place. Looks a little tricky but really it's not only took about 30 min
1 - 4 of 4 Posts
