1 - 5 of 5 Posts
i put 06 mirrors on my 00 now i need to rewire the plug, i have a truck side 06 plug harness, i need to find out which wires do what. these have the lights and heat on them. can anyone help or direct me to a wire harness diagram for both years?
thanks!!
Outcast Customs
I did this conversion a couple months ago. I plugged my 01 truck plug into the 07 mirror plug. That gave me the power mirrors back. Then I got my test light out and some multi-wire trailer wire and connected the mirrors lighting to the front corner running/blinker lights. Do each side separately. If you need the mirror heat you will need to run a separate toggle switch for that to work. The whole thing took less than an hour to do. I hope this helps you out...
Outcast Customs
My plugs were the same except for the amount of wires going into them.
mine are different, the door harness is only 4 wires and kinda sqaure-oval shaped. the 06 is rectangular, but i have the diff door plugs, just need to know what color wires are what.
thanks
1 - 5 of 5 Posts
