1 - 5 of 5 Posts
Cab on installer
Drain coolant down below the upper rad hose connection. Remove upper rad hose. Remove 4 bolts that hold thermostat housing on. Swap thermostats. Reinstall thermostat housing. Install upper rad hose. Fill coolant.
Cab on installer
I didn't. You could loosen it and move it over a bit if needed. My egr is gone so I can't remember if You need it removed.
1 - 5 of 5 Posts
