1 - 5 of 5 Posts
PSN Boss
Keep removing stuff until your too it lol. Just make sure you put pag oil in the compressor before hooking the lines back up to it and evac and re-charging it.
Hood Rich
No, its easy... You need to remove the fan, fan shroud, and tensioner. Get your self a 10MM and 13MM GEARWRENCH FLEXHEAD. take out the 13MM bolt first, its the bottom on rear. Lay the wrench flat on your hand, sneak it in, use your other hand and poke your index finger through the hole in the k member to hold the wrench on. the bolt will not come out, but it will drop. do the 10MM next, than do the top one. slide right out. bolts need to be in the new compressor as it goes in, I use grease to hold the bolts in.
Fixing Broken Stuff
You can take the fender well out and get it at it.
1 - 5 of 5 Posts
