1 - 20 of 20 Posts
utah get me two
i got the cups and cup driver tool from swamps.(nice guys)
i got the valve covers off today,and im going to pull the injesters:)
and cups tommaro.
but damm theres hardley any room to swing at the tool,on the passenger side
so you guys who have done it,
hook me up with the tips please,im wondering how to pull this off at the moment..
ps yea im changeing the cups in truck..thanks david
Custom Trailer Sales
Just curious why your changing the cups? Is one of yours cracked?
All done now
Might have to remove the passenger side motor mount and then lower that side of the motor to get more swing. Or just disconnect the passenger side mount and raise it up to get a better angle on it.
there is enough room, it just takes little whacks to do it. you will know when they are seated.
Can I ask how much the tool cost ya? Also where and how much are new cups? Can you buy just 1 or do you have to get all 8? Im pretty sure I have a cracked cup....
Ok I found it on Swamps site. $15 a piece. What about the tool to do it in truck?
<<< THE GAUGE WHORE...
remove the AC box cover... Makes a world of differance. Only 8 small hex head screws and then its not bad at all.
utah get me two
oh fok.
i pulled all 8 cups,ok cool ill clean the tool and put er back in the box
??? omg wtf.NNNOOOOOOO..
found the corner of the tap is broken.(pretty sure i broke it,but maybe it came that way,but again i dont think so)
looked on the ground
looked on the bench
looked in the engine compartment
looked in the old cups
looked in the cylinders ,with very tiny flexable magnet took
cannot find little chip of the tap anywhere
its about an 1/8 inch high,and 1/4 inch wide in triangle shape..
and actuyally looks too big to fit through cup hole
looked everywhere,if its in the cylinder,im hopeing it embeds imeadeatly apon start up.....
no i didnt put anything in the bottom of the cups,to block such an occurence
ok let the roasting begine,guess i deserve it,feeling like an idiot
and prolly gotta buy swamps a new tap to boot..stupid,stupid,stupid :(
I wonder how many times the tool had been actually used??? Things don't last forever. That really sucks about not having anything down in the bottom of the cups before you put the puller in there. Hope you find the broken piece and it's not in the cylinder chamber.
Headwind Magnet
Can you rent a borescope? Man, I feel for you. I'm on the wait-list at Swamps to borrow a set of tools. Sounds like a nightmare-ish scenario to me...
Best,
Jim
The tap I used from them back in August of 09 was beat up. I think all 4 flutes were cracked or damaged, yours probably came that way. Good luck.
I think you're supposed to throw a penny in the cup first. The shavings from the tapping process could also go down there right? So how was that rear p-side cup?
utah get me two
Discussion Starter #19
ok,all done..
broken piec of tap??? NOT IN ENGINE !! YAHOO !!!!
took me 20 hours :(:( i suck
runs good,and couls do it in 10 hrs now..
thank you swamps !!!!
Buffalo Diesel
I wouldn't want to do them in the truck, out of the truck though, 10 minutes.
The tap I got from Swamps was in perfect shape.
1 - 20 of 20 Posts
