1 - 8 of 8 Posts
I changed my oil to rotella Syn 5w-40. When I first started it after the oil change it started right up and faster than before. I put about 800 miles on it this weekend and its seems to be running funny. I cant quite put my finger on it seems to have a miss down low when your lugging it with no boost. When I would get off the highway and pull into a rest area it would have a funny idle too it and would not change until I shut it off and restarted it. This was my first highway trip not towing with my new injectors. And hot starting it cranks a little longer and seems like it does not want to fire right up like it normally does. I was running regular rotella 15w-40 before this. I have no codes or anything.
Thanks
Just a wild stab, but maybe your IPR is starting to stick a bit? The change to synthetic may have caused some gunk to get loosened up and make its way to the IPR? Really, I 'm just throwing it out as a guess if you're thinking its because of a change to synthetic. If not, then it sounds like IPR or ICP issues with the harder hot starts.
Discussion Starter · #4 ·
I talked to the guys at full force yesterday and he said put the 15w-40 back in it. I have a weak HPOP so its showing up more I guess.
only change I noticed was the inj's quieted down some after going to 5w-40 syn. Maybe my imagination but I think so.
they can actualy fuel better with a lower viscosity oil.... if you datalog and your mass fuel desired is toggling between some low number and 0 you just need a retune....
Road Hammer
Switched to 5-40 Rotella on my last change and the truck lopes a bit harder and such (had lope before due to tuning), but maintains slightly higher ICP I've noticed. Aside from that no noticeable differences for me.
My truck just seems to start easier when it is cold with a full synthetic. I would look at tuning or possible icp issue
1 - 8 of 8 Posts
