1 - 20 of 26 Posts
· <<< THE GAUGE WHORE...
Did your old turbo die? Or are you just going BigR?
· Registered
Discussion Starter · #4 ·
No the turbo is not dead... I was thinking about doing it on this turbo. But I due plan on going bigr but I need to close a few escrows before I can play with the truck some more. I am planning on going bigr in Late Aug or early Sep.
thanks for the info.
Andrew
· Body Type: MULE
Andrew
Andrew thank you for bowing down DUDE:redspotdance:
· Body Type: MULE
Their is some sarcasm in the sig. The truck is running really good :cool: Still havent been beat by a F 550
Thats because YOU havent run across me, BUT if my 550 dont beat you then I will
LMFAO:pullover:
· A Ghost these days.
It helped mine a ton. but I did everything from the mans to the Turbo outlet. I also might have regained just a bit of boost by fixing all the leaks in the up pipes. LOL
· Registered
Discussion Starter · #10 ·
I want CC everything also but will have to wait a until i got some free time and spare cash. What is the cost to do everything? I got all my boost leaks fixed and it did make a noticeable difference. :D
· HP Junky
I noticed a difference with the ceramic coated up-pipes. I got BWD's first set and did some before and after tests for him. They did make my boost needle climb a little quicker.
Which we all know is the one thing that you are looking for ;)
· Registered
How much is a typical Ceramic Coating of the turbo or up pipes?
Is someone working on better Up Pipes for the H2e setup?
· Registered
I would like to have a flexible connection to avoid future leaks.
· Banned
Wrapping the exhaust components is the absolute best way to kill them. Holds the heat in, but doesn't keep any of it out of the part like coating the inside would. Death to components comes from wrapping them.
Stock up-pipes are worthless. The collector and dounuts and pipe bs is hopeless. No provision to accomodate the unavoidable expansion/contraction.
I've killed three sets of them all new each time, including the pipes themselves, as if that really matters.
My guy in Ga charges me $18 per linear foot to coat the inside and outside of anything with the black 2000* stuff.
I would never in 2 million years even consider ever putting the stock up-pipe crap back on any engine it ever came off of. A set of DI uppies would go back on or I'd make some myself.
Almost every stock truck we have has some varying amount of exhaust leak at the collector/dounut region. They are STOCK. And yet I drive around at 1800degrees WOT with probably 2 or 3 times the drive pressure and......nothing, no leaks in the uppies. No leaks at all.
Now the manifolds are a different story... workin on that right now
.02
· AllYourBaseAreBelongToUs
Welcome Charles!
1 - 20 of 26 Posts
