1 - 6 of 6 Posts
duct tape and zip ties
ok i got a ? about the ccv mod instead of building a filter canister and running it back to the intake could i use a filter system like guzzle did on the coolant bypass filter mod? then just change the filter every so often i just figured it would be alot simpler than to change the filter than cleaning out the canister every so often i just dont know if the filter idea would cause to much pressure
riverjet
I blew about 300 bones on a bd /mann set up and it works great! (filter set up) I tried all the otheir set ups and they did not work for me. I had to hear all kind of stuff from......your awsome truck stinks man, to your truck has smoke underneath it. If you don't want to spend the money build your own canister from pvc and scrub pads. Do a search and you will find lots of info.
All done now
Mine goes from the doghouse, down to a PVC catch can, no media, with a drain on the bottom. From the catch can, back to the intake. Clean intake and no fumes.
That's a hell of an idea. I'll have to try that one.
yeah from the pics off of guzzles website it looks like you could just bolt it to the frame and then just change the filter instead of having to clean out the canister but idk if it would cause to much pressure though but im thinking that it shouldnt cause no more pressure than the canister type filter but idk
Metal - It kicks your ass
I built mine exactly like guzzles. I mounted mine in a different spot but so far it works great. It smokes every so often and i thinks thats due to the filter media i have in there which is very course. I will probably switch to a finer material when i change it.
1 - 6 of 6 Posts
