Could this be IPR or ICP related? No change with the one on the drivers side valve cover unplugged (icp?)
A buzz test sounded good, nice and loud all injectors sounded the same. The clutch is noisy or maybe that's gear rollover. It does seem to shake a tad more clutch engaged at idle. But I'm more concerned with the dropping idle and occasionally mild rough idle. Didn't know if those codes were related.does your truck have a manual transmission?
cyl 3 & cyl 8 are companion cylinders...
we see #3/#8 CCT faults on manual transmission trucks due to external balance issues (clutch/pressure plate/flywheel, etc)...
even bad torque converters on auto trucks can show 3 & 8 CCT faults.
basically any internal and/or external component within the engine or trans can affect the balance of the engine, and could be suspect when 3 & 8 are both consistently failing a CCT...assuming injector(s)/compression, etc are all ruled out as a potential (normal) cause.
