1 - 14 of 14 Posts
I need new tires for my truck and I can't decided which tires I should get. I can get either the BFG A/Ts or the Pro Comp Xtreme A/Ts for roughly the same price. I have BFG A/Ts on my truck right now and have had good luck with them. The Pro Comps are a directional tire, but also come with a 40k prorated warranty. I don't do any wheelin with my truck, I just need a tire that has good road manners, does well in the snow, and will last long. Any thoughts or opinions on either tire? I know the BFGs are a good tire, how do the Pro Comps compare?
Thanks
Michigan Ice Dog
I have ran both of those tires. I would go with the BFG as they wear OK, good road manners, and great in snow. If you did more wheeling off road, I would say go with the pro comps (awesome trail tire) I still run them under my 79 bronco. You didnt mention any heavy towing though..............
Super Moderator
I run the PRO COMPs 35x12.5x18 with great results so far. I rotate them at my oil changes, they aren't too loud on the road, the wide open tread pattern and the load rating is what I want in this size tire. I have the fronts at 60 PSI and the rears at 55 PSI.
The Fireman
I have never ran the Pro Comps but i can tell ya i wasn't to impressed with the BFG's I had. they wore good but traction sucked with them.
What size tire are you wanting? Best tire I have ever ran was a Bridgestone Revo. And would have ran them this time if they made them in a 35x12.50 so im running Yokohama Geolander A/T's now and they are damn good tires and the 2nd best of tires I have had.
I don't do any heavy towing, just a small atv trailer here and there. I am looking to get 315/75/16s.
8nout, how do the pro comps compare to the BFGs with regards to road manners and thread life?
Michigan Ice Dog
IMHO the tread life seemed to be the same but I liked the road manners of the BFG. They seemed to ride a little smoother on the road and stop a little qwicker in the snow.
there are better and cheaper tires out there then the bfg a/ts, personally after running them i hate them. next tire will prolly be a cooper or if money allows ill get some atzs
Michigan Ice Dog
Good point Countryboyrob. I know this is a little off topic as the origional ? was "BFGs are a good tire, how do the Pro Comps compare?" Personally I run goodyear at extreme (315/70/17) for everyday driving/ tow purpose. but on the fun weekends I run 37" military wrangler M/T
In the end I guess its personel pref.:shrug:
OBS junkie
If you like the BFG tread check out the General Grabber, seem to run as good or better for some & are cheaper.
Thanks for your opinions guys, I am going to try the Pro Comps and see how they hold up. I rarely get 40k miles out of tires so it should be interesting to see if the Pro Comps last that long.
can you run 315/70/16 on a stock setup?
well I never tryed the BFG'S but I run the revos,the revos are a great road tire! They are even better on wet roads! they only thing I dont like about them they dont like wet grass:doh: but other than wet grass they great in the snow and mud!
My buddy runs the pro comps, he got 45k out of his, and there's still probably a little under quarter tread left. They were 37's though, dunno if that makes a difference.
The Sound Of Madness
id go BFG, i ve ran them in mud, snow, sand, road never had a problem, great plowing tire, and they dont mind wet grass. i got about 40k out of them too.
I think the pro-comps have a 40,000 mile warranty, but I may be wrong...
I have 35" Xtreme A/T's and I love them. I had the BFG's on my last truck, they were OK, I will for sure buy the Procomps again when it is time.
1 - 14 of 14 Posts
