1 - 8 of 8 Posts
can you machine a obs housing and put the ball bearings in
Im sure it could be done
Why would you want/need to do that?
quicker spool up, more power, and spins longer after you shut it off, so it sounds cool
With injectors that turbo should spool plenty fast, if you want more go with a smaller housing. The power gain would not even be noticed IMO. As for the spinning sound after shut down... well, seems like alot of work/time/money for that "gain"
Long spool down after shut down...how does that work with reduced oil pressure?
BB turbos do tend to spin longer after shutdown... just the way they are because of the reduced frictional force in the bearings. Its really not any insane amount longer to notice if you werent the owner listeninig for it.
1 - 8 of 8 Posts
