1 - 6 of 6 Posts
So I have 3 injectors on the pass side allowing air to pass horrible during ICP leak test. I pulled the rail and put in Alliant Nipple cup seals. No help. I pulled the rail again and put in new Alliant seals on all 4 injectors top O rings that the nipple cup plugs into. Same result. Of course with the rail on you cannot see much but I cant see how they could be leaking at the top with new seals. Is it possible they are all leaking past the spool valves that bad?
Professional American, guarding our constitution.
Wouldn't it grow tighter around the valve with age as shoe polish builds up?
In my experience they do leak a little around the top. It makes trouble shooting a hpo leak difficult. I did injector top seals and nipple cups too and I could hear a faint leak of air still out of a couple. My truck runs good afterwards with no issues.
Yes, I've ran into this failure several times. I have another one in the shop right now having starting issues with only one injector spool valve leaking. They can leak bad enough to cause a no-start hot, or low ICP under load fault codes.
How did you fix this I have same problem can you just replace the spool valves or just put new injectors
I have an 06 6.0 and I rebuilt the injectors. Installed everything and both oil rails are full of oil but with a gauge I have no pressure! I have tried everything and can not get pressure! Anyone have any ideas? Please!!!
1 - 6 of 6 Posts
