I don't think it's perfectly balanced from forward to back, so you may have some tipping issues when you lift it off the frame. When I pulled my bed, I have a guy on each corner and it came right off, and wasn't very heavy, just awkward to lift/ hold/ walk with.I want to lift the bed off my truck to do some tank vent modifications.
How much does a long bed SRW bed weigh?
If I run a 2x6 between the rails front and rear will the rails support the weight of the bed if I lift it straight up?
I'll be using 2x6's on their edge, more strength that way but I will still be using two mounting points, one on each end of the board.If you are using the 2x6s on the flat I recommend 2 mounting points per board close to the rails. A 2x6 will bow quite a bit and could slip out.
