IM A CAT FIELD TECH THE ELC IS HARD ON HOSES AND SEALS, IT WILL MAKE THE HOSES SWELL AND GET SOFT AFTER A WILE, I WOULD RUN DEAC IF YOU WANTED TO RUN CAT COOLANT
Only other thing I would add is ... De-ionized water also works and to do a cooling system flush if your going to switch to something other than the Ford Gold.
Just to throw another name into the mix ...
International fills the Maxxforce 7 with Texaco ELC from the factory.
21 - 25 of 25 Posts
