1 - 5 of 5 Posts
My 96 cab looks like it is sagging slightly, body lines do not line up. Seems like the passenger side read of the cab needs to be shimmed. Is this something that has been done or is something else collapsed? Looking under the truck I was surprised how far in the mounts are. Everything looks solid around the mount and on the cab. thanks
Yes you can, the factory does. The real fix would be to buy new poly body mound.
Discussion Starter · #4 ·
on my jeep its got a bolt, on this i see a nut on a stud. after i pull the nut off, how far does the body need to come so i can replace them?
The nut does not come off. You will remove the bolts from inside the cab, then you can lift the body and put a washer in until desired height.
1 - 5 of 5 Posts
