I'm not in front of it right now but I believe that is still in there. I could be wrong thoughLooks like the sleeve that goes in the fuel pressure regulator on the secondary fuel bowl. Later models don’t use them though.
Ok I'll take that cover back off and look. Thank you!!No. Not there. It goes where the brass plunger is with the blue spring. It’s where the return line is bolted up. The adapter is held on with some torx screws.
Gotcha. Explains why I didn't see it to pull out. It wasn't there. Thank youIf you have a later model build you won’t use that
