1 - 7 of 7 Posts
Hello All,
It's time...:smile:
Can anybody recommend a Colorado Shop for a Dana 60 Swap?
Looking to get the swap and a mild lift done at the same time.
Thanks,
Mike
Administrator
Where at in Colorado.
I'm in Colorado Springs... but willing to travel to get it done right.
Administrator
it really is not hard to do yourself if you have all the parts, and you can save yourself about a grand.
Thanks for the reply,
I see a match set of 3.73 1 ton axles from a 2004 Powerstroke F350 locally.
Dana 60 leaf spring front and s sterling rear with disk brakes.
Does anybody know if they will bolt up to my 96 F250 ?
Thanks,
Mike
Administrator
yes, but they are not an exact fit. and you will have to use 99 and newer8X170mm rims. if it is a dually, you may have to use the 04 and newer 8X200mm rims.
your 96 uses 8X6.5 bolt pattern rims.
Administrator
Like said above. It's mostly bolts up. You need a rsk for a superduty axle, track bar bracket and a f350 pitman arm. If those axles still have the springs. I would snag them up too. The superduty leaf springs are a upgrade.
I believe there is some modding that needs to be done to fit superduty rear springs too. But it's not too bad.
1 - 7 of 7 Posts
