1 - 3 of 3 Posts
I have an 03 Coachmen Aluminum bodied camper. The outside is really dingy
So.....step 1.....attempt to clean it. Wrong. Started taking the paint right off.
What's the best stuff to repaint it with?
Shouldn't take us more then a day to clean, tape it, and spray it. Rather do that then keep fighting a losing battle cleaning it. Plus I will know it's done right and will last a lot longer than the factory mist job they put on it.
Thanks
John
ERJ Aircraft Mechanic
I used to work for an RV dealer. That sort of thing you should be able to either contact Coachman thru a dealer or directly and get a PPG or similar paint code number for the color paint originally used.
I had to do that with a Jayco once, the service department was doing some fiberglass body work on it.
( Slaps head! ) I totally forgot about Mr. TG. Shouldve went str8 to the source.
Thank You sir!
1 - 3 of 3 Posts
