1 - 14 of 14 Posts
I had to pull my Fabtech bars off the truck to install my truck camper tie downs that mount to the frame. I have a 3" lift in the rear of the truck, consisting of a 5" block and stock springs.
Looks like Cal Tracs would be the best for my set up. I have installed a set on a Excursion with F250 springs that work great.
I remember seeing an article in Diesel Power with a lifted F250.
Would I order them with longer bars??
I'd email Travis VanKirk at Calvert - travis at calvertracing.com. He answered all the questions I had before buying mine.
Regards,
Michael Pliska
Discussion Starter · #5 ·
Hater Club
What is the most lift you can run with the regular Cal-Tracs as of now?
There isn't a set limit really..
I called them up, told them my setup and they sent the correct parts. There was no "order this part number" crap. This is how the 5 minute conversation went:
me: " I have a '99 srw f250 with the camper package and tow setup. It is basically a f350 rear suspension. I also have air bags and 3in drop shackles."
Calvert: "No big deal we have all the parts in stock, here is your price.. I can get it shipped today."
me: "Here is my credit card number and info."
Calvert: "I'll email you shortly with a invoice copy and tracking info. Call me or email me anytime with any questions or concerns."
Discussion Starter · #8 ·
What is a camper package? I thought it was 4:10 gears and a larger rear sway bar?
Hater Club
On the f250, the camper package was upgraded rear shocks, f350 springs\overload, and larger sway bar. 4.10 gear was separate option and I think you had to get the f350 for that.
With the springs I have and the 3in drop shackles, the rear still sits as high as a stock f350. :doh:
With 2000+lbs on the hitch\bed, she rides level. I had 2 7.3's in the bed and hauling a loaded 12k trailer as well. The air bags only needed 20psi to level out the rear. If I didn't have the drop shackles, it probably would have been level.
Discussion Starter · #10 ·
On the f250, the camper package was upgraded rear shocks, f350 springsoverload, and larger sway bar. 4.10 gear was separate option and I think you had to get the f350 for that.
I thought the block was the only difference between 350-250?
Any pics of them installed?
1 - 14 of 14 Posts
