1 - 2 of 2 Posts
Going to install my Recon/Dodge cab lights today. Will need to remove the factory lights first and will save them to go on the '06. Do I need to pop the "A" post trim and pull the headliner down? Or is there more to this?
6Leaker
I would pull the a-pillars and just flop em down, then pull everything else back to the second doors, this way ya got enough room to easily work. This will just drop the front of the headliner enough for ya to be able to work around it.
Also not sure if you have it but you will need hardware to bolt up the recon pieces, and a second person to work the nuts/bolts.
1 - 2 of 2 Posts
