Is it worth 16k? Cause if it blows that's about what you'll have in it. You might get lucky and get in it early enough to fix it before it hurts anything else. 6.4 trucks are know to hydro lock and bend a rod
Hydrolock from what the head gaskets or what?Is it worth 16k? Cause if it blows that's about what you'll have in it. You might get lucky and get in it early enough to fix it before it hurts anything else. 6.4 trucks are know to hydro lock and bend a rod
Always seemed more logical to me that it would get ingested into the intake when the egr valve opens and it takes a big gulp.I remembered they call lock up due to the egr cooler failing and allowing it to back through through the exhaust manifold and back through the exhaust valve.
that's how rods break or turn into a pretzelAlways seemed more logical to me that it would get ingested into the intake when the egr valve opens and it takes a big gulp.
It's a regen issue, fills the cylinder with fuel then you shut the truck off before regen is complete.... Fire it up with cylinders full of fuel... Bam bent rodHydrolock from what the head gaskets or what?
I've got a dmax aswell they have there own set of issues lolgood god I have always heard the 6.4 was a good engine......No thankyou I will stick with my 6.6 yes guys I'm a duramax guy but I work on a lot of fords. Don't hate me lol I like ford pickups just not their engines
LOL I suppose I should have expected that rebutle in ford land lol. they all have their issues but not 17k in a duramax I have seen them go 200k with the piss beat out of them and not loose a head gasket. I believe a lot of it has to do with the tuning. too bad there wasn't efi live for ford.I've got a dmax aswell they have there own set of issues lol
232k miles
Waterpump
Cp3(twice)
Injectors (twice)
Transmission
Head gasket
Drive shaft
The entire frontend (twice)
Gauge cluster (3 times)
Drivers seat
Window motor (drivers twice)(pass once)
And a whole lot of other stuff.
I'm an owner and I will say I've had more issues with my dmax then either one of my powerstrokes (2) 2005's 1ton 191k 3/4 ton 92k
I work on all 3. 4 if you add in a few vw tdi's I personally think dmax's are more reliable but they go down as hard as 6.4. Just finished lly 174k blown head gasket both heads cracked coolant in oil damaged bearings new long block 13k 100% stock. Also have lmm broken crankshaft 219k waiting customer approval. Not to mention lb7 crankcase full of diesel fuel 130k scheduled for Thursday and another lb7 220k needs pump and injectors for Tuesday. they all breakLOL I suppose I should have expected that rebutle in ford land lol. they all have their issues but not 17k in a duramax I have seen them go 200k with the piss beat out of them and not loose a head gasket. I believe a lot of it has to do with the tuning. too bad there wasn't efi live for ford.
