1 - 5 of 5 Posts
Right Wing Radical
I have acquired an aftermarket bumper for a 2005-2007 F350.
What do I have to change to bolt it up to my 2002 F350?
Thanks, Jim
Administrator
Bolts right up. You will have a gap under the grill because the 05-07 grill is bigger by about and inch or two.
Right Wing Radical
OK. That is what I thought, looking at pics side by side.
Are the grille attachment points similar enough that I could swap to a 2005-2007 grille also?
Thanks a bunch!
Administrator
The top will line up but the the bottom won't. You can make some mounts or zip tie it. Best way to do it, is get a 05-07 header panel and grill. Might as well do the headlights too. 1a auto has a good price on everything you need.
Right Wing Radical
Thanks for the info.
I was hoping to avoid swapping the header panel(and lights), but if that is what it takes...
Thanks again for the help
Jim
1 - 5 of 5 Posts
