1 - 15 of 15 Posts
I'm at the tail end of building a 1933 RatRod using my father's old 1999 F350 7.3L as a donor vehicle.
I'm working on the electrical side of things now and looking forward to getting this beast running....
201959
PSN intsigator
Welcome to the nation from WNC
That's the only picture you give us??!!! Welcome! I look forward to more.
With the torque that the 7.3 has you may have a hard time keeping rear tires on it. Even a gentle nudge of the throttle will start them to spinning on that light of a machine.
Give us some info, automatic, or a 6 speed. Chipped or stock?
Thanks! It's 4wd, automatic, uses basically the full drivetrain from the F350 Dually Crew cab. The funny part is that it's a 1933 Chevy body on a custom frame I made, and with the Ford drivetrain and electronics. Usually people build 1930's Fords with a Chevy drivetrain. I went the opposite route.
Triangulated 4 link suspension on the front and back axles. Radiator in the rear with fans. The batteries fit in that container behind the front wheel.
I would love to see a video of it going down the road once it is completed....
I think it will be several hundred pounds lighter than the truck was, but that engine and transmission are crazy heavy. I think they're just under 1000 pounds as a whole.
...and the 2 axles are super duty axles as well. They're hard to even roll without being attached to anything.
The truck weighed around 7,000 lbs empty
A 99 F350 would have been north of 7500#. Just curious - Never mind... you have it in the title.
Thats is SICK bro! I wish I had the skill to do fab work like that. I wouldnt be able to drive it around here though, roads are so bad it would rip the bottom off LOL
Thanks! It's on airbags. That pic shows the stance fully deflated. It's 1 inch off the ground. Inflated, I get about 10 inches of clearance.
The frame is the air tank. I have several leaks I need to track down after I pull it all apart and finish weld everything.
Rough roads won't matter, he will only hit every 4th or 5th bump once he gets going.
  • Like
Reactions: heavydoc
PSN intsigator
Project Shamu
Welding up frames and making them air tanks is a biiiiiitch. Ive tried to do it several times, and everytime it ends up seeping through a perfectly good weld.
Good luck! Can't wait to see it complete!
1 - 15 of 15 Posts
