1 - 20 of 43 Posts
Lost a half the nozzle tip on #8. How much damage did it do and where do I go from here?
Try to fish the chunk out or pull the motor and head and check for damage? Thanks
What else?
Pull the injector and get a borescope to look down in there.
I don't think you'll see anything pleasant, I would plan on pulling the head, depending on what you see after looking at it with the borescope.
Dave
Nope no luck on the bore scope yet.
Good luck on getting one small enough to fit through an injector bore.
They make them that will fit easily through a 7.3 injector hole with the cup installed.
They are right at $17,000.00 for the one I have seen that will take pics/vids. We use them to inspect bearings inside large gearboxes.
Thats what I'm afraid of but would like to make sure.
if you need any help with anything let me know. oh and that was post number 1,000.
Post whore :),
and yea I need your help, I need to borrow a bore scope so I can see whats up with the top of the piston before I throw another injector in there. Not know is driving me nuts.
hmmm, im not sure i know of anyone with a bore scope let alone one small enough to look in there. are you just trying not to pull the head?
i could be wrong but after you remove the cup it wouldnt be much bigger then with the cup in would it.?
<<< THE GAUGE WHORE...
The hole is no bigger with the cup out...
Yank that thing Gordon...
As much as that sucks.
Buddy of mine lost an injector nozzle on a stock AD truck last week. Swapped a new injector in and the truck runs fine. Who knows if the missing nozzle parts are embedded in the piston, but the truck runs fine so he's just gonna go with it. This might not work in your case, but I thought I'd share.
1 - 20 of 43 Posts
