1 - 2 of 2 Posts
I was changing the mechanical pump on my 96 and the bottom part of the old pump broke off in the motor need an idea of how to get the piece that broke off out of the oil galley
Bigfoot is an OBS
Depending on how high up it broke off, grab the plunger shaft with vise-grips and pull straight up.
Or, get a large wood screw and screw it into the housing. You'll want something with very aggressive threads to do this. The housing is a very soft aluminum alloy, so it will drill easily, but also strip out easily if the threads are too fine.
1 - 2 of 2 Posts
