I have the GOS wiring harness and the Silverstars. It is a little brighter then stock. If I had it to do over again I would not of wasted money on that junk. I bought a 55 watt HID set from Retro Solutions and it is literally a night and day difference!.....NO JOKE!!!!!!! I will post of pics ASAP.They can be run with the stock wiring. The reason for upgrading the wire is with the upgrade your headlights will be running direct off the battery and just using the old headligt connection as a trigger for the realays. You get much better voltage this way and gives any light about 20 percent more light output
