High pressure oil leak test using air had leak at standpipe on left head, (o-ring brittle and it is new). After replaced air leak test is still coming from branch tube area. Anyone had this issue and had it repaired. Wondering what the cost for repair that since you have to pull the rear cover and if done in truck remove some of the rockers????? I'm an old Ford diesel mechanic and this is bothering me since the flat rate hour now at the door is $210.00
