Never seen one without at least RABS. Call them and talk to them.
A lot of Excursion and SuperDuty owners suffer from brake shimmy/pulsing brakes. Some describe it as a "warped rotor", when in fact it's uneven pad material that's been transferred to the rotor due to hot spots in the metal.Thanks Stewart for the instructions. What is wrong with the regular rotors?
Hi StewartA lot of Excursion and SuperDuty owners suffer from brake shimmy/pulsing brakes. Some describe it as a "warped rotor", when in fact it's uneven pad material that's been transferred to the rotor due to hot spots in the metal.
No amount of turning the rotors fixes the problem, but replacing them with cryo treated rotors like the Cryo Powerslots or ART rotors, coupled with a good pad like Hawk LTS pads or EBC pads, does.
The standard or non-cryo treated Powerslot's are still susceptible to hot spotting.
Whenever you do change the rotors, make sure you use a two-step torque method. Torque all of the lug nuts to 80lbs first, then 165lbs.
Don't forget to bed in your new pads to the new rotors properly.
Stewart
Yep, aint nothing like having the rotors freshly turned, going down the road and feeling a smooth brake pedal, only to have the shimmy back by the time ya get home!...that they almost re-form instantly when put back into service.
Those are SOLD INDIVIDUALLY DA!!!!on edit Summit racing has cryo powerslots for $179 a pair
here is the link http://store.summitracing.com/egnsearch.asp?SearchType=Make&N=700+4294908331+4294906247+4294924666+4294922533+115+4294839009&NeXID=5
Andrew
OK, Andrew, I take it back. Good job helping out a fellow member.Thanks Andrew!
While you are there, why not bleed the whole system? I do this ever couple of years. Come look at my vehicles. All the brake fluid looks clear. Most cars have black fluid.Why calipers??? You are going to have to bleed the entire brake system
I do this at least once a year on my Lightning. Sometimes twice, depending on how much I've autocrossed and drag raced throughout the year.While you are there, why not bleed the whole system? I do this ever couple of years. Come look at my vehicles. All the brake fluid looks clear. Most cars have black fluid.
