The brake pedal slowly goes to the floor when pressure is applied. It has a new vacuum pump, new power booster, and a new master cylinder. All the brake lines and the ABS valve under the cab on the frame rail has been bleed more then a couple of times. The left rear brake was out of adjustment, but it was adjusted and still the same. The caliper pin slides need to be cleaned and greased. The brake pads and shoes all have good life left to them. When you drive it there seems to be a delay in the power brakes, then it grabs hard then seems normal, but then the pedal goes to the floor slowly. The truck sat for a couple of years, so could this be a stuck caliper or wheel cylinder? Could it be a collapsed brake line? The thing is I think it is is the new power booster. The vacuum pump makes a noise like it is by passing the vacuum when it is connected to the power booster. When you disconnect the vacuum line from the booster and put your finger over the line to draw the vacuum the pump stops making the noise. I think thats all the details. Any ideas? Thanks in advace.
