1 - 1 of 1 Posts
Ok here is the situation went to put rear calipers on my truck couldn't get the parts for a bit so it sat on blocks with open rear brake lines for about a week or so. Go to put them back on and bleed them like you normally would right rear first even bled the fronts...it will build pressure without the motor running but as soon as it runs the pedal goes spongy again bled everything I can think of any ideas I'm out of patience and time to work on it anyone had this problem
1 - 1 of 1 Posts
