1 - 6 of 6 Posts
STILL LEARNING
What size the the hard line that goes from the front of the truck to the rear axle? Mine is rotten off and I need to replace it. If you have the nut size too, that would also be helpful
O this on my 99 F550
STILL LEARNING
Nobody has to replace a brake in in these things?
It's 1/4" brakeline, I forget what size wrench
TennesseeHillbilly
Mine did the same thing....I went to a local Royal Brass and Hose shop and got them to make me a length of tubing with the nuts installed and the tube flared on both ends...about 25 dollars. IIRC the line is 1/4" and the fittings are 3/8-24
STILL LEARNING
Thanks Guys. I am gonna Get some of that copper/nickel alloy stuff so it will not rot out
1 - 6 of 6 Posts
