1 - 12 of 12 Posts
BROKE as a JOKE
My brake light is on, but only sometimes. Most of the time, it fades on and off.
The resivoir is full, i have good brakes and pedal feel, and the e-brake holds well. Any ideas?
I've had the same deal for 2 years. It was doing this before Vac pump died, and still does it to this day, after reploacing it. Good luck, I hope you can find it.
BROKE as a JOKE
Discussion Starter · #5 ·
thanks. as long as i have brakes, i guess i dont give a ####.
stupid thing wasnt on today when i drove home, but it was on this morning after a chilly evening.
i bet its some corrosion in the wiring or sending unit that acts up depending on the weather/time/mood/tidal patterns.
...................i hate electrical gremlins
trust me, when/if that vacuum pump lets loose (if that is it), you'll wish you'd replaced it sooner. Luckily mine crapped out in the driveway, you just need a puller to get the pulley off. When that thing let loose I couldn't stop it, lol and it was just rolling down the driveway
do you hear any weird chirping noise from that area of the pump?
BROKE as a JOKE
Discussion Starter · #7 ·
no weird noises. runs like every other 7.3 ive heard. dad's fleet of 94-97 7.3's all had to have the proportioning valve replaced...i'm going to bleed them when i do the rear shackle mounts and see if it helps
lol ive never seen it happen, i would have been laughing my ass off
check your vac with a gauge you may have a bad or going bad hose ot the white hard line on the heater box. see if when it dose it if you chage the heater contriolls if you hear a hissing or see the vac gauge droppin goff
my light come on when e-brake pedal vibrates down, i just push it up and the light goes out.
1 - 12 of 12 Posts
