1 - 9 of 9 Posts
So I was towing my camper with my 2006 6.0 F350 when I had to get on the brakes and suddenly it pulled hard to the right. It did this the rest of the way to the campground, about 40 miles. Got out and checked and all the wheels were covered in brake dust BUT the front passenger was clean and caliper was cold which should have been the left caliper not working. Truck has all newer discs, pads, fluid and all stainless braided lines. Now I just got home and it stopped perfect the entire way. Thought the pins might have been seized but it shoulda been the left side. What should I look for and why did it start working fine?
don't play well w others
Probably a bad supply line. Inside collapsed, and did not allow fluid transfer. By sitting, it finally relaxed, and returned to normal. Problem will more than likely reoccur, and more frequently in the future
How though? Theres no rubber lines on it
"resident smarty pants"
There is a hose inside the stainless braid - usually made of teflon. What brand of hose did you install?
Stainless has rubber inside.
These were russel lines
I would think that they would be fine - pretty good quality from my experience.
That said, anything is possible I guess.
When was the last time the brake fluid was flushed?
I would probably keep an eye on rotor temps for awhile. An IR temperature gun is a mighty handy thing to have.
Discussion Starter #9
Yea I have one and will bring it with me this time. This truck doesnt get used much so Id say theres bout 2000 miles tops on all brake parts including fluid
1 - 9 of 9 Posts
