1 - 16 of 16 Posts
im looking in getting a bov for the 08 f350 to get rid of turbo bark..my truck is spartan tune 250, 5" exhaust and s&b intake..I would like to know how much for kit, and how hard to install??
give Aaron at dpfdeletekits a call.......919-636-1518
he is a sponsor here and he will take care of you for sure!
Not hard at all.Call Rudys and he'll set you up.Took me about 3 hours but I didn't know were to mount anything so there was alot of time on the phone.I think with his new pipe you don't have to grind the support either. edit Spatel beat me to it!!
Texas Member
price$$??
PSN Insomniac
I did it, and im pretty slow when it comes to doing things. 5hrs for an Airdog, but its right.
The BOV is addictive.... so is taking everything further.
Rudys has it all.
If you buy the IC pipe then there is no cutting or welding. Just have to wire it up pretty much. This should help.
http://www.dieselperformance.com/productManual/1047210-14-20-25_Turbo_Guard__BOV_1.pdf
Forgive my ignorance here, but why couldn't you just weld a bung on for *any* blow off valve?
IE the HKS Racing valve, or the Tial minus the microprocessor stuff?
Why is the microprocessor stuff necessary on a automatic pickup?
None of the imports require this type of stuff.
Just trying to learn :)
The imports are carbed and have a throttle plate that creates vacuum when you release the throttle. Diesel's don't create vacuum so without the microprocessor, it doesn't "blow off".
I've worked on plenty of turbo'd import cars.. none have had carb's.. :)
didn't know they didn't have a throttle plate.
Interesting.
Went from a cheap mod (import) to dam near a payment on the truck :)
IM OUT!!!
Interesting.
he means your throttle body!
1 - 16 of 16 Posts
