1 - 16 of 16 Posts
I bought some chromemoly pushrods from Rudys diesel they look great the only problem I have is that they are shorter than stock pushrods is this normal?
stock pushrods are 9.849
chromemoly pr are 9.797
that is 0.052 difference or almost 1/16 of a inch
will this make the engine (6.4 job 1 with stock cam) act different ?
or is this one of Ford changes?
I have talked to rudys and elite they say that they with work
but I need more information don't want to have to go back in over 0.052 of a
inch.
Cab on installer
There fine. Just be sure to bump the engine over a few times with the valve covers off to make sure the lifters pump up and nothing jams up. There shorter for the guys who deck there heads.
bring the chain
the pushrods for a 6.0 diesel are exatctly 9.847.
the pushrods for a 6.4 diesel are exactly 9.800.
the cam in a 6.4 is higher,so they can run the hpfp faster.
i would call rudy
I measured these pushrods with a set of calipers
Are u telling me I might have 6.0 pushrods in a 6.4 engine?
If so me and Ford need to talk because I bought the truck new in 08
bring the chain
if the pushrods you installed are 9.800? then yes theyre the correct length for a 6.0. if thats the case you dont need to talk to ford,you need to talk to rudy. from your original post it says you removed 9.849(9.847 corrected) and installed 9.800 from rudy./ the truck had the correct length pushrods in it.
The Early 6.4 engines came with longer pushrods that were the same as the 6.0. They have been superseded to a shorter pushrod (by Ford). Our pushrods are a drop-in replacement. You will be fine.
This post is confusing because he is not working on a 6.0, its a 6.4. Either way he has the correct pushrod.
bring the chain
he said he installed 9.800 they are the correct length for a 6.0. i didnt know they superceded to a shorter rod. im aware he is working on a 6.4
fast 6.0 is right
I found out that Ford did change to a shorter pushrod part
#8c3z-6565-B can't find out why but they did so my chromemoly
pushrods are fine . thanks for all the info.
fast 6.0 is right
C10H20
just being a smartazz, "chromoly"
C10H20
great the last thing i need is a spelling coach
Didn't mean anything by it, a lot of people call it chromemoly even the pro's. But hey just think next time a whole bunch of people are talking about it and saying it wrong you can look like the guy that knows his chit and educated them :bowfast:
And your talking about the Rudy’s diesel Chromemoly push rods
1 - 16 of 16 Posts
