1 - 1 of 1 Posts
Found a boost leak.
Passenger side where the boot goes into the head on the underside of the turbo housing.
Can I rotate the turbo up a few inches to replace the boots by doing the following:
1)Remove the two bolts on the turbo that attach it to the block
2)Loosen the clamp that attaches the exhaust pipe (up-pipe) to the backside of the turbo
3) loosen the 4 clamps that hold the 2 boots to the heads
Do you think that will give me enough room to replace those two boots?
1 - 1 of 1 Posts
