1 - 8 of 8 Posts
i can see that its leaking out from under the housing between the pedestal and the ex. housing or where the up-pipes meet..... do ya think its leaking from the where the donut gaskets meet the housing? or the pedestal? its starting get pretty clicky....no boost gauge yet so i cant give you bosot numbers sorry... whats the best way to find out exactly where its leaking and try to fix it?
ok, ill search for threads about them now but im still gonna ask for a write up on how to best get back there and do them
any ideas????
See post #6 on this thread for how I did it from above (without removing trans):
removal of turbo... grrrrrrr - Powerstroke Nation
Unfortunately the GM up-pipe donuts (recommended by some people) did not seal worth a dang, so I had to repeat the excercise a month later. That time I chose to pull the trans since I had a leaking torque converter seal. It was definitely easier to do it with the trans out, but I would have to say the overall effort was lower when doing it from the top side. Unless you have access to a lift to make pulling the trans easier!
Regards,
Michael Pliska
Premium Member
Regards,
Michael Pliska
hmm I would look into that had I not already planned on upgrading my TC/
Unfortunately I'll have my trans out AGAIN next week, but this time to install a billet torque converter. I also need to seal some intake plenum leaks, will probably do the driver's side when I do the trans (since it looks nearly impossible without pulling the turbo AGAIN, and I might as well have easy access to the up-pipe connection when I do it).
1 - 8 of 8 Posts
