Just seeing if anyone has run into this or has an answer for it. When giving the go pedal a mash and after rpms climb and boost reaches 30-35psi my gauge starts to flutter pretty violently. Is it because that's around the end of my max boost anyway? It will fluctuate 3-5psi rapidly as I see it. I would think it should stay smooth. I was reading various forums just searching google and one person made the comment that this will happen when the engine can't flow anymore air that the turbo is forcing at it.
My other thought is that I am using a cheap @ss gauge to be honest. Just a $10 Amazon type. But it goes up to 50psi so it's not the normal issue with gauges where it goes bad from pegging out. I don't mind buying a better brand gauge, but it would be stupid if the issue is from something mechanical.
Note that I am running a brand new KC300x turbo. It's not surging or fluttering that way, just my gauge needle. I do leave the wastegate disconnected as well because I like the way the power comes on hard and instantly. Would that effect anything like this at all? The performance of the engine/turbo feel 100% fine and nothing noticable is wrong. If the gauge wasn't there I'd have no second thoughts on it.
