So I'm on my way to work. Just cruisin at 70 mph getting ready to pass some cars- I was running late for work. As I slow down I look in my rear view mirror and see SO much white smoke that I can't see anything. I pull over and pop the hood and holy crap I've never seen so much oil. I blew out the line that goes to the drivers side head. It blew at the fitting on the head. This line was not leaking at all prior to this. I'm changing the lines and strip the fitting on the HPOP. I take a close look and no hump on the back cover! I had the 15 degree pump. It's like it was meant to strip so I can get the 17 degree. Got it back together this afternoon and she's purrin' like a 7.3 should. The line blowing out was a surprise because no leak prior or any sort of warning. I've never even had the lines off before. I've used up about a case of degreaser to clean all the oil out from under the hood. I wonder how badly the people behind me got sprayed? Oh well, just wanted to share. How common is it for these lines to blow?
