I have had a bleed down issue for a couple weeks now. When the truck sits overnight the reservoir will bleed down and it takes forever to start.
I have confirmed it is the res bleeding down by sticking the dipstick in it before I started it up after sitting all night.
I went on a trip and gave the truck a pretty good work out. Got home and fixed the UVC harness issue I had and when I fired it up that day, it started immediately.
So the bleed down issue "went away" for a couple days.
Now it's back and worse than ever. I can let the truck sit just an hour or 2 and it bleeds all the way down.
I can crank til oil pressure comes up on the dash, and the truck starts immediately.
I have plans to check the HPO reservoir gasket to see if that is allowing it to bleed down, but I suspect not since I couldn't get ANY oil on the dipstick, even below what I think is the level of the gasket.
What else could cause this? The things of which I'm aware are
Check valves (how many and where?)
Worn front cover (I hope not)
LPOP (I have no trouble swapping in the Melling
Let's hear your thoughts.
Thanks
Thanks
