1 - 8 of 8 Posts
So my neighbor decided to come over and see what the blank I was doing. Fine, Fine, I’ll humor you. Out of no where he bumps the heater hose I have tucked up out of the way and some residual antifreeze bleeds into the passenger head....
How much? I’m thinking half a cup maybe a cup. Can I just drain the fresh oil I just put in and be ok? If this was a gas engine I’d drain and go on with my life. Since I’m new to Diesel’s I figure it’s best to ask.
PSN intsigator
If it were mine, I would drain the oil, and pour some new oil down the spot where the coolant was spilled, let that drain. Fill her back full and so nothin else but give that neighbor distance he can't cross when there is an open engine.
"resident smarty pants"
1 cup is 1/16 of a gallon. The entire oil system is around 18 (edited - quarts - thanks masakimm). If it is fully mixed, it would be at 1.35%.
I like the suggestion above. After it is all back together and has been run a bit, you could do an early oil change if you were worried about it.
Native Texan
Uhmm 18 gallon maybe 18 quarts. but no just drain it out you will be fine. Antifreeze gets into blocks all the time That's why I take the drain plug out and leave it out till the motor is buttoned up.
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
Oh shoot - I was still asleep!! Thanks - pretty embarrassed over that one!! Definitely 18 qts!
Ok didn’t get junk so but then you read about the glycol affecting bearings, and blah, Blah, blah. Its like reading webmd. It just makes you nervous.
Plus I’m not used to the 5 gallon of oil thing yet.
Native Texan
Thats only if u run it with alot of antifreeze in the pan and make a milk shake out of ur oil. Now antifreeze in a transmission then be afraid very afraid.LOL
PSN intsigator
Yep, what Mikey said
1 - 8 of 8 Posts
