My 2004 F-350 CC with 157k miles just started blowing a little black smoke constantly at idle which increases to lots of black smoke as the throttle is opened and RPM increases. If you blip the throttle a bit you can see some white smoke too mixed in with the black smoke. Power, turbo boost and acceleration seems to be OK. Fuel pressure shows about 70 psi with blue spring mod. Smells like fuel and not coolant. Not loosing coolant. Oil level is normal.
No codes are set. EGR valve was cleaned about 1000 miles ago. FICM, turbo, EGR cooler, oil cooler and head gaskets replaced for FORD parts years ago. Stock original injectors with no tuner. Atlas 40 FICM tune installed years ago. Archoil and synthetic 15W-40 Rotella T-6 has about 3000 miles on it with Amsoil bypass oil filter installed. Bypass coolant filter also installed years ago.
FORScan shows MAP, Baro and EBP all about 14.7 psi with KOEO.
I suspect over fueling. With engine warmed up, sitting in the driveway and revving the engine for a minute resulted in unburnt fuel dripping off the passenger side exhaust manifold and leaving a black 6 inch stain on the driveway. You can see the black stains where the exhausted unburnt fuel dripped off of the underside of the manifold at cylinder #7 in the attached photo (passenger side rear cylinder). I know that I need to pull off the exhaust manifold and install a gasket and new bolts, but suspect this is not the cause of the current over fueling situation. Photo seems upside down. It was taken on my back under the vehicle shooting up at the underside of the manifold.
I have not pulled the EGR yet or taken it to the Ford dealer for injector contribution testing yet. Sure seems like an injector overfueling, but no injector codes set yet.
What do you suggest as next steps?
