1 - 10 of 10 Posts
Truck won't start and I suspect it to be the ignition. Batteries are good but wanna know where would be the best place to order an ignition. Thanks
what kind of ignition are you talking about?
truck wouldn't start, but someone told me on FTE to tighten the the 2 bolts under the steering column. It will be later this evening beofre i get home to it.
ok, diesels dont really have ignitions like a gasser does, essentially the "ignition" is the compression that causes the fuel to combust. If there is a starting problem it is either fuel (pump, injectors, etc) or computer (IDM, CPS, and other sensors and computers) related. Im not sure what tightening two bolts under the steering column will do, never heard of that but im no expert so who knows.
CPS?
The Oracle
he is talking about the ignition switch.
its on the column about 6-8inches below the wheel...held on by 2 bolts
probably not the issue
The Oracle
and we need more info...."wont start" really doenst do sh!t for us.....
does it crank, not crank? if it cranks is there any smoke?
is the oil full?
WTS light come on?
can you read codes or have some one that can?
It cranks when it wants to I should say. I just got home and it hasn't done it since. But once it doesn't start again I will tighten those two bolts.
Oil is full and it doesn't start. Def not cps from what I was told where it doesn't die when driving.
Canadian Eh
Cps can just quit and cause a no start, is the tach moving while cranking?
If its not turning over it could be a starter....
next time it doesnt crank try hitting the starter with something.
1 - 10 of 10 Posts
