1 - 11 of 11 Posts
How do I loosen the belt tensionor on my truck is there some trick cause I can't get it loose.... need to replace the alternator..
Powerstrokin'
Re: Belth Tensionor
find a socket that will fit the bolt thats in the middle of the idler pulley an with your break over or ratchet jus pull towards passenger side and it should spring back and let you get the belt off.
Re: Belth Tensionor
yeah that's not working. It is extremely tough, i can only budge it a little bit using all my might... not enough to get anything off... I don't see a spot to use a pry bar either to get the tension off...
Powerstrokin'
Re: Belth Tensionor
huh thats weird.... not sure what to tel ya:confused:
What else?
Re: Belth Tensionor
Ensure that you would be loosening the bolt first, and that you are on the bolt for the pulley, and gently hit the tensioner with a hammer, in the area where it bolts to the engine, it may be seized.
Dave
theres only one torx 50 bolt on the tensioner, I assume thats the one.
IIRC there's a bolt on the tensioner itself, but also one that goes through the pulley. It's the pulley bolt you need to be on.
the bolt on the pulley itself.. won't that just take the roller off? I"m alittle confused..
It's tight enough to put your ratchet on it and move the tensioner...again, IIRC.
The one with the Torx bolt is not the tensioner, it's just a pulley.
The tensioner is farther down the passenger side front. With the motor running you should see it shimmy up and down as the engine idles. Grab that pulley with a long breaker bar and socket and pull on it (lefty loosy), then take the belt off.
it worked!. Thanks everyone, new 250amp alternator installed!
1 - 11 of 11 Posts
